Setting up your Zipatile
Components
- Zipato Zipatile Controller
Process:
  • 1. When you turn on your Zipatile, first connect it to the internet
  • 2. Go to app menu, then tap on settings, and at the top you will see the Wi-Fi icon
  • 3. Tap on that, and turn on your Wi-Fi
  • 4. Find your network, and connect to it
  • 5. When you connect to your network, go to AppRepo and see if there's any new updates for your ZipaTile
  • 6. If there's any updates, update them all, but first tap on refresh button on the right top corner
  • 7. When you are done with that, next step is to register your Zipatile
Is this article helpful?
0 0 4
