Components
- Zipato Zipatile Controller
Process:
- 1. Go to Zipato app
- 2. On top right corner tap on the icon for main menu
- 3. Then go to Settings, and tap on Device Manager
- 4. When application are loaded, enter for example Zwave devices
- 5. At the end of your Zwave list there is an recycle bin icon
- 6. Tap on it, and then tap on yes to delete this device
- 7. When you are done deleting, perform SYNCHRONIZATION and REFRESH
- 8. You successfully deleted device
