Components
- Zipato Zipatile Controller
Process:
- 1. Log to your WEB UI here: https://my.zipato.com/zipato-web/app2login
- 2. After logging in go to Device manager --> IP --> Internal --> Settings
- 3. Now go to Configuration, and you entered the internal settings
- 4. In there you can change offsets, sensitivity, alarm sounds,...
- 5. Set it up as you wish
