When system is armed in HOME mode, Home Exit Delay is used to set the maximum time period after you arm the system, in which you can trigger the zone which is set as "exit zone". During this time, Zipato will not trigger the alarm if you are detected by any of the zones which are set as "follower zone" or "exit zone". Please note that once after you are detected by the "exit zone" you can't go back as even "follower zone" will trigger the alarm.
Related FAQs
Properties
