Exit zone is the one which will be tripped last after you arm the partition. Once after you arm the partition, the system will count "exit period" during which you can trip your exit zone while exiting your home. Once after it's being tripped you can't come back in your home again, as this will trigger an alarm.
Related FAQs
Properties
