If you go out of home, and use your key fob to arm/disarm the system, you won't be able to see or hear any confirmation signal from the alarm panel. This is why Zipato allows you to use as many actuator devices in your home (e.g. lights) as you want, to give you the signal when successfully armed or disarmed.
Related FAQs
Properties
