Inclusion of zipato RGBW bulb failed on Jeedom with openzwave
Alexis Guével shared this idea 4 years ago
Unfortunately after many trials I'm unable to include my zipato light bulb in my zwave network. Setup information :
- Jeedom v4.0.61 , dongle zwave usb badodosecurity wd6051, plugin openzwave v1.4
- zipato light bulb rgbw
steps I followed and results I get :
1. Controller in exclusion mode -> OK
2. I'm turning light bulb on -> message "exclusion of a device not in the network"
3. the controller close the exclusion mode (when I'm tapping it does not do anything ..)
4. Controller in inclusion mode -> OK
5. Turning on light bulb (when I'm tapping it does not do anything)
6. the controller close the inclusion mode right after I turned the zipato bulb ON
I joined some logs with this post, I see errors like this :
[2020-11-18 00:38:02][DEBUG] : zwcallback args=[{'controllerState': 'Failed', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 8, 'controllerErrorDoc': 'None.', 'homeId': 3880691758L, 'controllerStateDoc': 'The command has failed.'}]
[2020-11-18 00:38:02][DEBUG] : Z-Wave ControllerCommand : {'controllerState': 'Failed', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 8, 'controllerErrorDoc': 'None.', 'homeId': 3880691758L, 'controllerStateDoc': 'The command has failed.'}
[2020-11-18 00:38:02][INFO] : The command has failed. (Failed)
Also this in the other log fileatr thre same time, during the inclusion
2020-11-18 00:38:02.461 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-11-18 00:38:02.461 Info, ADD_NODE_STATUS_FAILED
2020-11-18 00:38:02.461 Detail, Removing current message
2020-11-18 00:38:02.461 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-11-18 00:38:02.462 Detail, Notification: ControllerCommand - Failed
Will appreciate some help ! I see my interface updating when I'm try to include it, and logs, so I guess something happening but somehow the bubl can not be added.
Thanks a lot
I suggest to address this problem in the openzwave community. Looks like the openzwave interface has not handled this bulb in a correct manner.
Hello Alexis,
tapping on the bulb was not working with me, did you to tap on the bottom on your lamp like on this old post ? it worded for me on Jeedom
domotique34.com/ampoule-led-rgbw-de-zipato/
