How to use API to turn a switch ON/OFF?
Abdalrahman Hassanine shared this question 9 years ago
Hi everyone
Can anybody give me an example on how to use API to turn a switch ON/OFF?
I'm using Micro Module Switch Double
I want to control it from an external application using HTTP requests
and I don't want to use virtual switches
Thank you,
Well, im not sure how this can be done without using virtual devices. Virtual switch would not help anyway, you would need to use vitrual sensor as that has a direct http link where you only need to insert the status 1 or 0 manually at the end.
Sorry, I meant Virtual Sensor ... Thanks
5
so, how to get the "ep" and "apiKey" numbers?
and what about local? is it available?
Thank you,
Did you find out how to get the "ep" and "apiKey" numbers?
It's not an easy find.
After you navigate to STATE, press Settings button, and in URL field you will find complete link with ep and apiKey filled in.
Now I get it. It has to be a viritual switch. I tried with a z-wave switch. Now i created a viritual switch and it works.Thank you.
