can't get fibaro fgs221 state return
Hi everybody,
I managed to get my roller shutter (fibaro fgs221) state return but without success.
If I use the manual switch ( UP or DOWN) , the zipabox still showing the previous state , without updating the display (even if I refresh the page).
Can anybody provide me some help ?
Thanks in advance
are you receiving the status from other devices?
It does seem to work only with a long delay.....
with the v0.9.961, I have the same problem :
No event in the log when I press the switch (on S1 - bistable)
That's good to know ! I will wait for a fix then ;)
thanks for the reply
Hello Orphee,
the same here with the fibaro dimmer modules.... No live feedback...
Hello Orphee,
I am currently trying to check this also over other Fibaro's devices like the roller shutter FGR221. If I manually change the roller shutter status then I see in the events the log, while if I change manually the roller shutter the Zipabox doesn't read the actual status even after days. So basically the same problem here reported for the dimmer.
I completely agree with you, I receive the status from AEON switch even if I switch it manually. Do you have even a rough forecast on when you will implement the feedback from Fibaro's modules to Zipabox? How is the workaround status you mentioned in your reply.
Thanks for your answer
Marco
Marco
