Components
- Zipato Controllers
Process:
- 1) In order to use the cluster feature, ALL of the controllers you're planning to add to it MUST have a valid PRO licence
- 2) Go to the Multibox tab, and click "Create Cluster", confirm the window that opens with YES
- 3) Refresh the web page
- 4) Go again to the Multibox tab
- 5) Select the S/N of the created cluster, and copy it
- 6) Paste the copied S/N of the cluster to the every controller you have
- 7) Go to your first controller, afterwards select the controller settings tab, and at the end you will have a ZIPATO CLUSTER box
- 8) Paste the cluster S/N in that box, and SAVE it
- 9) Same procedure goes for the other controllers
- 10) When you have finalized adding all of your controllers to the cluster, it is IMPORTANT to save everything by clicking the SYNC button
