Zipabox and Zipamini serial number is located on the back of the Zipato Controller, make a note of it as it will be required when registering your panel online.
The serial number of Zipatablet and Zipamini you will also be able to find in "Zipabox" application.
When you turn on your Zipamini and when you start your "Zipabox" application will find:
- Serial number
- Status of connection to the Zipato Cloud Server
- Firmware version which is currently installed on your controller
- IP address
- MAC address
