Zipato IR Extender should work with any Z-Wave controller or gateway that has control capability for “Thermostat” devices.
Knowledge Base
General Information
Zipato V3 platform
Rules Creator - Zipato V2 and V3 platforms
Zipato V2 platform - Getting Started
Zipato V2 platform - Adding and Managing New Devices
Zipato V2 platform - Virtual devices
Zipatile1
FAQs
Related FAQs
- What happens when adding new device is interrupted?
- I can't connect any Z-wave device to my Zipato controller
- I have a problem with the device, what information should I provide to Zipato Support?
- What should I do if I am having trouble installing my device?
- How to Manage Device Names and Visibility in Zipato Control Center?
- How to add supported IP Camera in Zipato Control Center?
- Mini Keypad RFiD/Z-Wave - Why doesn’t it read tags?
- Mini Keypad RFiD/Z-wave - The buttons on don’t work
- Mini Keypad RFiD/Z-Wave - I can't include it into my Z-Wave network, what am I doing wrong?
- Mini Keypad RFiD/Z-Wave - the indicator light doesn’t go on for 1 second but blinks 6 times
- MM Motor Controller - The shutter move direction is reverse
- MM Motor Controller - LED light work fine, but can not control it
- MM Motor Controller - is not working and LED is turned off
- Zipato RGBW bulb - How to add?
- IR Extender - How to select my air-conditioner IR code from Zipato IR Extender?
- IR Extender - Can I use 2 or more Zipato IR Extenders in my house?
- IR Extender - Avoid the IR interference if I am using 2 or more air conditioners at same time
- IR Extender - How do I know which product is compatible with my Zipato IR Extender?
- IR Extender - Can I use the USB port to configure Zipato IR Extender?
- Zipato 3G USB Stick - Installing and configuring
Properties
Author
Guest
