If device shows up in “Device manager”, in belonging Network protocol, delete it and then add this device again. If that device is not shown in “Device manager” window just add this device again.
Knowledge Base
General Information
Zipato V3 platform
Rules Creator - Zipato V2 and V3 platforms
Zipato V2 platform - Getting Started
Zipato V2 platform - Adding and Managing New Devices
Zipato V2 platform - Virtual devices
Zipatile1
FAQs
Related FAQs
- What happens when adding new device is interrupted?
- I can't connect any Z-wave device to my Zipato controller
- I have a problem with the device, what information should I provide to Zipato Support?
- What should I do if I am having trouble installing my device?
- How to Manage Device Names and Visibility in Zipato Control Center?
- How to add supported IP Camera in Zipato Control Center?
- Mini Keypad RFiD/Z-Wave - Why doesn’t it read tags?
- Mini Keypad RFiD/Z-wave - The buttons on don’t work
- Mini Keypad RFiD/Z-Wave - I can't include it into my Z-Wave network, what am I doing wrong?
- Mini Keypad RFiD/Z-Wave - the indicator light doesn’t go on for 1 second but blinks 6 times
- MM Motor Controller - The shutter move direction is reverse
- MM Motor Controller - LED light work fine, but can not control it
- MM Motor Controller - is not working and LED is turned off
- Zipato RGBW bulb - How to add?
- IR Extender - How to select my air-conditioner IR code from Zipato IR Extender?
- IR Extender - Can I use 2 or more Zipato IR Extenders in my house?
- IR Extender - Avoid the IR interference if I am using 2 or more air conditioners at same time
- IR Extender - How do I know which product is compatible with my Zipato IR Extender?
- IR Extender - Can I use the USB port to configure Zipato IR Extender?
- Zipato 3G USB Stick - Installing and configuring
Properties
Author
Guest
