Zipato RGBW bulb - How to add?
1. Screw the Zipato RGBW bulb in standard E27 socket
2. Turn ON your wall switch
3. Log in into Zipato Control Center
4. Go to the “Device manager” button on the left sidebar
5. Press “Add new device” button
6. Please find and choose Z-Wave network protocol
7. Exclude (reset) of the device before inclusion (always good prior inclusion process) - Activate exclusion mode of the RGBW bulb by GENTLY TAPPING the bulb
8. Include the device - Activate inclusion mode of the RGBW bulb by GENTLY TAPPING the bulb
9. Automatic synchronization of data between your Zipato Controller and Zipato Cloud Server will be done
10. Congratulations your Zipato Door/Window Sensor has been added successfully
Tutorial:
Is this article helpful?
1 0 1
