Philips Hue supported?
I'm interested in the Zigbee addon for the Zipato box. Especially since the new Philips Hue smart bulbs communicate using Zigbee.
This would mean that the Zipato box could control these bulbs. Correct? Would it, for example, be possible to program rules which set the color of the bulb?
Once it becomes widely available in Europe, we will consider to support it. For now, I don't think it is possible to do it as it seems to me, they are not using Zigbee Home Automation profile.
Just for the information of those interested : Philips Hue (and others similar products of GE, Greenwave, OSRAM Sylvania) uses the open ZigBee Light Link (LL) standard/profile, which is able to interoperate with Home Automation (HA) profile.
It is hoped that the support is effortless for Zipato with the ZigBee HA module, and it could happen quickly ?! ;)
Regards,
Regards,
hi there
In the dutch forums many hue users are willing to buy the zipatobox but only if the HUE and LW with Zigbee light link is supported. Please support this.
hi there
API released today
http://developers.meethue.com/index.html
API released today
Did Zipato start supporting Hue at the moment?
I will buy Zipato if Hue en Greenwave are supported. Please consider making this possible!
J'ai une zipabox depuis plusieurs mois...
I have a zipabox for several months ... When my guests are interested, I give them a little demo and they are super excited. They ask me the same question! "This is consistent with the Philips bulbs?
I think that with the hue api released, everyone with some programming ability can make it work with zipabox, even if not supported out of the box.
Example. You can make some php script (or something else) running over google drive, that use api's to interact with the lamps (with or without a password). Thank within zipabox you can call script functions from rules.. simple!
@Ray internet loosing connection could be an issue.. but it's simple to solve.
simply using a raspberry or similar (eg. beaglebone black ) that host a web server with all you need.
But, really.. worried about loosing internet connection for a logn period? I lost my connection only 2 time in the past 4 years.
Anyway, I'm talking about a solutions waiting the native solution.
But I think that also, without official support, the script+web server solution could be a good solution to drive hue.
guys, theres no need of a server. The "circle" box hs already a server inside. The only need is that the light and the zipabox are in the same network (and you should enable the developer user following the guide here http://developers.meethue.com/index.html )
attached a screen of a simple rules to increase/decrease the light.
Anyone know if i still need the Philips hue controller or if zipato zigbee extension would be enough?
Situation is like this; Phillips Hue bulb is on Zigbee smart lighing. Zipabox zigbee extension support smart lighting as it is basically the same as smart home profile. However, philips hue bulbs can't be restarted (which is necessary for pairing the zigbee device) without the Philips color lighting remote control (round one, with scenes button). Otherwise, they are being automatically paired with the Philips hue gateway.
Anyway, I wouldn't hurry to buy Philips Hue now, as there will be few supprises on the market soon;-)
Maybe the same type of device but using zwave? ;)
Sebastian,
I saw that Zipato has started to communicate on your new RGBW bulb. Could you sum-up the advantages of your solution? Do you will just release one kind of bulb or are you thinking to expand also your offer? Me, I am looking mainly for a solution for replacing my down-lights and I was considering buying Philips Hue BR30. Ideally, I would like to find something even brighter. I am afraid that your current offer will not fully meet my needs. Nevertheless, I remain open-minded and will buy maybe some bulbs for additional lamps.
I see clearly the advantage for a direct integration and to avoid using a bridge. But I am also afraid that more third-party applications will pop-up from the hue community due to the number of users. Do you also investigate how we will at the end take the benefit of your solution? Especially how we can integrate the lighting with home-cinema experience (i.e. lighting colors changing with music and/or images on the screen depending if we are listning music or watching a movie...).
Sebastian,
Sebastian,
I see
investigate how we will at the end can take the benefit of your solution?
depending if we are watching a movie or just listening music...)?
Sebastian,
I see
The main difference is of course, Z-wave instead of Zigbee. Z-wave is currently much wider adopted so much more people will be able to use it.
Besides RGB LEDs, Zipato bulb has warm white and cold white LEDs additionally. This means that customer are also, able to adjust white color temperature, when using bulb for everyday lighting.
As for the controller, I think what Philips is offering is not comparable with Zipabox. I don't know how big is their community, but ours is not small neither. And Zipabox has open API and bunch of the features already implemented by us, so I think controller should be our point of sales;-)
Also, our development was focused on PCB inside the bulb, so we are able to integrate it to various kind of LEDs afterwards.
I suppose the good thing is Zipato might actually fully support these devices unlike almost all of my existing standards compliant z-wave devices.
When will the Zipato RGBW be available?
It is available already. You can buy it here: http://www.domadoo.fr/shopexd.asp?catalogid=3804
Same price as Hue :-(
Ok. I see. I was looking fot it on Dutch websites. Can you also give me the dimensions of the bulb?
The colorscheme's of the Hue are different from the colorschema of the RGB. Also the way they are connect (GU10 for example) and how Hue present the light. In several controllers they are allready supported by using the open api of the bridge. For that reason I would still want to ask you to support them in your controller. Because of the open api is relatively simple to control them. I allready can control them by a HTTP request in the rulecreator.
Intergrate them in de devicetable would give the advantege of read there statusreport and control them more simple.
Same request for me. I can understand that Zipato support firstly their Zwave Bulb, but Philips Hue are used by many more peoples. I don't know if there is a technical way to support Hue with Zipato Zigbee Module (profile issue ?) ? But if it's not possible with zigbee, you should at least support those Hue bulbs with HTTP. There is a public API available.
Yes, please Philips Hue support! Philips Hue is almost standard in the most major smart home solutions ;-)
Any news on the support of Hue?
What's the situation here? No Hue support is a deal breaker.
will be supported within a two weeks. Meanwhile, you can use http request puzzle within a rule creator
please see the attachments, how the rule, and configuration in our system how you can use HTTP Request and some virtual, or real switch to control Philips Hue.
The example provided here will allow you to turn the 3rd bulb in the hue bridge that is located on the given IP, and is being controlled with newdeveloper user on the bridge.
/api/newdeveloper/lights/3/state
/api/{user on bridge}/ligths/{bulb name}/state
the bulb will have the following settings what can be seen from json:
hue value of 25500
brightness value of 200
and saturation value of 255
parameter "on" can be true for bulb on, and false for bulb off
json in body of http:
"on": true,
"hue": 25500,
"bri": 200,
"sat": 255
For more reference on the requests, how to set up hue and how to use
HTTP Rest API from Philips ( paths, attributes, ...) , please consult
Philips Hue API, where all the requests are appropriately explained.
Regards,
Hrvoje.
hue value of 25500
"on": true,
"hue": 25500,
"bri": 200,
"sat": 255
Regards,
Hrvoje.
Sebastian,
That is great news. Looking forward to it!
Sebastian,
Hello Sebastian,
This is a great news that Hue will be supported natively.
Any news about this support ? We are now 2 weeks since your last message ;-)
Thank you
Hello Sebastian,
Thank you
Just look in the add device wizzard in the new UI.
I get the error message: Configuration Failed :-(
I also get the error message: Congifuration Failed :-(
When will it be supported ? Will you still need the Hue controller ?
no support on philips hue is a no-go-to-buy
Hurry up please. .. it's too long. i thinks to change my box with a edomus box :)
Support for hue and sonos is a must> I Wil buy zipabox.
Good support for Nest and Netatmo is a pro
Hi again - just wondering on progress with Hue integration? Any updates on ETA?
Thanks,
Danny
Thanks,
Danny
I am also waiting for proper support on philips hue.....
Strange... the ZIPABOX had the option to include Philips Hue. It states to press the button on the bridge, but... nothing will ever happen.
Toooo bad! I purchased ZIPABOX while being under the impression it would work together with the Hue bulbs.
Please ZIPATO, your support is needed in the matter. Thank you, V
today i got it working on the new 0.9.999.4 firmware
i had to click the buton on the hue a few times and did a retry but i worked.
in the lights i section i got several hues visible...all with the color options eventhough only 1 of my hues has that option...some things could use fixing but for now i am happy happy happy
oh and it is added as an ip-device not as a zigbee device (which i had hoped/expected)
Great news, I have successfully added mys hue bulb :)
Everything work perfectly.
I was also now able to add the Hue bridge, and on second add new device attempt it added lights aswell in device manager... But none of those are shown in Lights & Power menu, or in rule creator devices, etc.
I changed the lights' type to RGBW bulb and checked show as device. Is something else needed?
Trying to add the bridge again for 3rd time from add new device fails.
I think Zipato has not finished the functionality of the Hue hub.
I also added the Hub successfully. The bulbs appear in Lights & Power all with the same description "Philips Hue Bulb" but I can't control them.
"Re-apply device descriptors" from the old UI finally did the trick for me, and now works perfectly!
I have the Hue Bridge now linked and see the Lights in my portal (thanks ymppa for the re-apply trick). However, none of the bulbs respond currently to commands. Will continue trying another time.
I can't connect the hue bridge. The re-aply trick didn't work for me. At 57 seconds het gives a 'failed' sign.
too bad.
too bad.
Any news on this ? I'm waiting for it to be official supported before buying a hue kit.
It's really easy to use Hue without special support. You can find my example rule here.
Any news?
Any news?
I know I can control the Hue with HTTP REST calls, but I would like to receive the bulb status as well and make rule decisions based on that
You should be able to add Philips hue with ADD NEW DEVICE option from main interface.
It works. I can include the device now. Thank you.
Would there a chance to connect the bulbs, adapters (smartlink), led-strips and living colors (Bloom etc.) directly to zipato in the near future, like it is by Osram lightify ??
I have had the hue lights connected for a couple of weeks now but they regularly stop working. Can control them via hue app or directly to the hub API but nothing works from the zipabox.
Anyone else having stability issues with hue?
I bought a Zipato RGBW bulb................... having some doubts about it, when turned to red, it is pink...... colors seem way off.
I added a Hue Bridge. At first there were no lights. The second time it recognised the lights also. But I can't switch off the lights. When I turn the bar down to 0% they stay on at low level. Do more people have this problem?
I also would love to see the option to add the white colors to the color (RGB) selection.
Edit: I made a rule where the brightness of the light is checked. If the brightness is 0 send an http post to the hue bridge (/api/{user}/lights/{id}/state with value {"on":false"}).
And maybe an idea (stolen from the hue app) make the sliders under Device Browser -> RGB bulb the current color of the light. :)
Thx
Thx
My Zipato cant find my Hue Bridge at all. Tryid 10 times - is it due to Phillips issue a update for the Bridge or what!
I got it to work like this:
1. You need to get the units
random generated username, this you can get like this:
è http://<bridge
ip address>/debug/clip.html
è Put in url in the box
/api
è In message body put in {"devicetype":"my_hue_app#iphone
zipato123"} and press PUT “Rememeber to push the Phillips Hue Bridge just
before pressing put”
This will generate a encrypted
username to use in a HTTP request like this:
Success “username” 1028d66426293e821ecfd9ef1a0731df (Take what ever it generates here)
The HTTP request in my Zipato rule looks like this to turn on my lamp:
Method: PUT
URL: http://Brige_IP/api/1028d66426293e821ecfd9ef1a0731df/lights/1/state
BODY:
"on": true,
"hue": 25500,
"bri": 200,
"sat": 255
The lights names 1 to XX
you can find on your HUE mobile app etc.
è http://<bridge
/api
Method: PUT
BODY:
"on": true,
"hue": 25500,
"bri": 200,
"sat": 255
Hi Martin,
Great "hack", I have the same issue as you, can't get the Zipabox to include the Hue Bridge.
I hereby implement you solution, thanks - and await an official Zipato fix hopefully soon...
Hi Martin,
Zipato are you here? What is the ETA for a solution ?
Don't you need a zigbee module to your box?
My hue bridge is working fine, but new Hue bulbs are not recognised.
I've added some new lights to the bridge (without any issues, working fine in the Hue app), but my Zipabox (firmware 0.9.999.8a) can't seem to find them.
I've tried to re-add my bridge from the web interface (without removing it), which resulted in configuration failed
How can I add the new bulbs to my Zipabox?
Hey, I have a ticket open, because my box does not find the bridge and hangs after the search. The search is finished with "configuration failed". The Team told me, that they found the error and they are working on it.
Great news!
In the meantime I've found a workaround. I've created scenes in my Philips Hue app to configure all bulbs and I use a http-request to the Hue-api to start/stop them
Great news!
anyone knew how to add a new buld or how to get the information regarding new bulbs from the bridge without delete/adding the bridge?
