Manage associations
Components
  • Zipato Zipatile Controller
  • Zipato RGBW LED bulb
  • Fibaro Button
Process:
  1. Before adding your Zwave device into association, please read the manual of your device for association groups
  2. Go to Zwave and find the device you want to associate
  3. Go to settings and select advanced
  4. Select Manage Associations
  5. Select the group you want to use, and after that add the device that you want to associate
  6. Click on device and drag and drop it into Devices in group x
  7. Afterwards go to send feature and click on it
  8. Follow the instructions below
  9. Afterwards click on retrieve feature
  10. Follow the instructions below
  11. Close the window
  12. Press SAVE and SYNC
Is this article helpful?
1 0 0
