When using Zipato Backup Service (1 Year), complete Zipato data will be backed up including all paired devices.
However, Backup data can be restored only to the same type of controller i.e. if you are backing up Zipatile1, that Backup can be restored only to Zipatile1 controllers (to the same you were backing up or some other Zipatile1 controller).
