Components
- Zipato Zipatile Controller
- Fibaro Button
Process:
- 1.) To remove device from group, first go to Zwave
- 2.) Then go to the settings of the device that has an association with the other device
- 3.) Click on ADVANCE and then go to the MANAGE ASSOCIATIONS
- 4.) Go to association group and select the group that you want to remove, in this example it's the Group 2
- 5.) Press on the right mouse button and you will have an option to remove the device from the group
- 6.) Press SEND and follow the instructions below
- 7.) Press RETRIEVE and follow the instructions below
- 8.) Perform SAVE and SYNC
