Adding NEST Thermostat
This tutorial demonstrates how to add the NEST thermostat trough the Zipato Control center.
Requirements: Zipato Controller, NEST Thermostat
How to add NEST thermostat on Zipato Controller:
1.Connect your NEST thermostat to your home installation. If you dont know how, check out the NEST thermostat's manual.
2.Click on the 'Add new device' option.
3.From the list, select the NEST thermostat.
4.Register your NEST thermostat on nest.com to recieve the activation pincode.
5.Accept Zipato features on your NEST account, like shown in the video and use the pincode to activate your device.
6.Your device should now be activated and functional.
Tutorial:
