How to delete a device?
1. Log in into Zipato Mobile Application
2. Go to the “Main menu” in the top right corner of the application
3. Select “Device manager”
4. Choose network of the device you want to delete (e.g. Z-Wave)
5. Go to the device you want to delete and click on icon of the device
6. After you click on the icon of the device, trash/waste Bin will show on the top of your device
7. Click trash/waste Bin in order to delete this device
6. In the pop-up window confirm deletion of the device
8. At the end automatic synchronization of data between your Zipato Controller and Zipato Cloud Server will be done
Remove (delete) a device in Zipato Mobile Application
Is this article helpful?
