Component:
- Automation
Process:
1. Select "Dashboard" from the main menu
2. Click on the room widget to add new room
3. Click the "+" icon in the lower right corner to add a new room and define its name (mandatory) and description (optional)
4. Click on the room settings to edit its inputs (name/ devices/ photo) or to delete the room
5. Select "Devices" and click the "+" icon in the lower right corner to assign new device
6. Click on the room widget to see all devices assigned to the room
7. To add another room click on the "Rooms" title and then click "+" icon in the lower right corner to add new room
NOTE: To edit room data click either on the 3 dots in the widget or on gear icon in the room details screen
