User - Edit the Dashboard
Component:
- User
Process:
1. Select "Dashboard" from the main menu and click on the Edit button
2. Click the "+" icon in the lower right corner and select a container to add under the dashboard.
3. Select device abilities to add in the custom container and click "Next"
4. Enter the group name and click "Save"
5. Click "Save" to create new container
6. New container group is created on the dashboard.
NOTE: Containers can be used to add several user-defined groups under the Dashboard. Each container group can be edited under the Edit button and by clicking on its title to open Edit/ Delete buttons
Is this article helpful?
1 0 0
