1. In the upper right corner select the Edit option.
2. You can delete or edit the existing containers by selecting the dots on the side next to the container and pulling it to the left side of the screen. To add a new container select the Add button ("+") in the bottom right corner.
3. Select the type of container you wish to add. For example the Quick Info container.
4. Select the widgets you wish to add to your container.
5. The new container will become visible. After you are done adding the containers select the Save icon in the upper right corner.
6. If you add multiple widgets to the Quick Info container you can see the widget you are currently at by looking at the selection bar under the container.
7. You further customize the Home Screen by selecting various containers and widgets you wish to see.
