Welcome to Zipato Help Center
Share your ideas or submit private requests. Your feedback is highly valuable for us all.
Categories
Knowledge Base
Zipato V2 cloud platform - End of life 1.1.2024. | Nov 27, 2023 |
Zipato V2 platform - End of Support Life | Dec 31, 2021 |
Knowledge Base
General Information
- How does Zipato work
- What is Zipato
- Zipato Advantages
- Can I install Zipato at home and is it easy to use?
- Zipato Energy Management
- Zipato Home Automation System
- How to use scenes [advanced pt.1]
- Manage associations
- Manage associations- removing device from groups
- Zipato Security Benefits & Features
- Controller Backup
- Zipato Security Management
- Zipato Comfort Management
- Interactive monitoring and alerting
- Explanation for ZWNTUT option (new Network heal)
- How to make knxip configuration
- Zipato Backup / Restore Service
Zipato V3 platform
- Dashboard - add new type
- Zipatile2 - Registration
- Zipatile2 - Home Screen Edit
- System - Create a system
- System - Add a server (controller)
- System - Add a subsystem
- Device - Adding a physical device
- Device - Adding a virtual device
- System - Redeem Zipacoin coupon
- System - Settings
- Automation - Create a rule
- Automation - Create a room
- Automation - Create a scene
- User - Create a user account
- User - Create a contact
- User - Edit the Dashboard
- User - Add a member to the system
- Server - Settings
- Virtual thermostat - create Thermostat2 zone
- Zipato V3 platform - migration from V2 to V3
- Google Home - reset token
- Wallet - Redeem Zipacoins coupon
- Wallet - Activate license
- Wallet - buy Zipacoins
- Automation - enable Geofencing feature
- Automation - create Geofencing rule
- Virtual thermostat - add Thermostat PRO license
- Server firmware upgrade
- Virtual alarm - create virtual alarm partition
- Virtual alarm - configuration
- Virtual alarm - zone settings
- Virtual alarm - user permissions
- Google Home - link Zipato System
- Updating the Zipato firmware via Mobile App
Rules Creator - Zipato V2 and V3 platforms
- Introduction of Zipato Rules Creator
- The Blocks
- How to create a Rule?
- Rule malfunction
- Rule Example - Motion activated light
- Rule Example - Intrusion activated light
- Rule Example - Receive push notifications via PushingBox and Newtifry
- Rule Example - IFTTT - Use DO to control actions in Zipabox
- Rule Example - IFTTT - Use IF to control actions in Zipabox
- Rule Example - Presence Simulator
- How to copy rules in rule creator
- How to use groups and how to make a rule with them
- How to create a PUSH notification with the Rule Creator
- How to use METER puzzle
- The Blocks
- Rule Example - Roller shutter activated with sunrise and sunset
- Rule Example - Closet light activated by Closet door
- Rule Example - Home/Away (Mini Keypad RFiD) activated light
- Rule Example - Home Away Detector
Zipato V2 platform - Getting Started
- Where is the serial number on Zipato Controller?
- About Zipato Control Center Application (Web GUI)
- About Zipato Mobile Application
- Creating Account with Zipato
- Network heal
- How to use scenes [basic]
- How to create a cluster
- Meet the Zipabox
- Meet the Zipamini
- Control Center - How to Sign in?
- Control Center - Register your Zipato Controller
- Control Center - Clear (unregister) a Zipato Controller
- Control Center - Factory Reset on Zipato Controller
- Mobile Application - How to Log in?
- Mobile Application - Register your Zipato Controller
- Mobile Application - Establishing Local Connection
Zipato V2 platform - Adding and Managing New Devices
- Adding new devices in Zipato Control Center
- Adding new devices in Zipato Mobile Application
- Remove (delete) a device in Zipato Control Center
- Remove (delete) a device in Zipato Mobile Application
- Zipato Multisensor Trio - Adding
- Zipato Door/Window Sensor - Adding
- Add Zipato IR Extender
- Zipato IR Extender AC Configuration
- Zipato IR Extender - Control AC with Virtual Switch
- Zipato Z-wave remote - Adding
- Zipato Indoor Siren - Adding
- Adding Smoke sensor on Zipato Controller
- Adding NEST Thermostat
- Adding an IP Camera
- Zipato RGBW LED Bulb with a dimmer
- Zipato MM Switch Single - Adding
- Zipato 3G USB Stick - Adding & configuring
- Zipato Mini Keypad RFID/Z-Wave - Adding
- Zipabox ZigBee Module - Connecting and installing
- Zipabox 433MHz Module - Connecting and installing
- Zipabox EnOcean Module - Connecting and installing
- Zipabox KNX Module - Connecting and installing
- Zipabox Power Module - Connecting and installing
- Zipabox Backup Module - Connecting and installing
- Zipabox Security Module - Connecting and installing
- Zipabox Security Module - Configuring zones
- Zipabox Serial Module - Connecting and installing
- Zipabox P1 Module - Connecting and installing
- Zipabox P1 Module - Installing and configuring DSMR Electricity Meter
- Nexa Receiver - Adding
- Nexa Transmitter - Adding
- Philips Hue - Adding
- Global Caché - Adding & managing
- Somfy RTS - Adding & configuring
- Sonos - Adding
- PulseWorx - Adding PIM-U Powerline Interface Module (USB) - UPB
- PulseWorx - Adding AM1-12 Appliance Module
- PulseWorx - Adding LM1-4 Lamp Module
- Virtual Switch - Adding
- Virtual Thermometer - Adding
- How to add Amazon Alexa to your Zipato system
Zipatile1
- How to remove Wall holder from ZipaTile
- Setting up your Zipatile
- How to register your ZipaTile
- How to remove device from ZipaTile
- How to install 3rd party apps on ZipaTile
- How to move, remove, and uninstall apps on ZipaTile
- How to access your SD Card on your Zipatile
- Internal settings on Zipatile
- Touch manager
- Zipatile gesture movements with Zipato's RGBW bulb
- How to set up a lock screen
- How to do a MASTER RESET on ZipaTile
- How to add DoorBird to ZipaTile
- Zipatile- Network Connection
- Internal app MQTT client documentation
Recent Activity
Showing 10 of 1752 items. Load More
